The local TPKX file and SLPK file cannot be loaded in apk
84
Thursday
LiuYuhang
Unity Version:2021.3.6f1
local file path: Internal storage in the root directory / GIS
local file format: tpkx and slpk
tpkx: use for basemap, basemap layer type has set imagelayer
slpk: use for 3DObjectSceneLayer
In Unity editor mode, everything works fine, but when packaged as APK, no errors are reported and the model and base map are not loaded.
Can you tell me exactly what is not done well? thank you
code:
Unity Editor:
player setting:
LiuYuhang
手动在android/data/com.xxx.xxx/file下创建文件夹,并将tpk文件和slpk文件放入后,使用Application.persistentDataPath路径后,加载成功。
原因暂不清楚
WilburYoung
直接在arcgismapcomponent.layer图层添加slpk文件相对路径就可以了
private void CreatGSLine()
// Create ArcGIS layers and add them to the map
var layer_1 = new ArcGISLayerInstanceData();
layer_1.Name = "MyLayer_gs";
layer_1.Type = LayerTypes.ArcGISImageLayer;
layer_1.Source = Application.streamingAssetsPath + "/你的数据文件.tpk";
layer_1.Opacity = 1.0f;
layer_1.IsVisible = true;
//layer_1.Authentication = ;
arcgismapcomponent.Layers.Add(layer_1);
LiuYuhang
目标平台为安卓,谢谢,不过我也会试下直接在Inspector里面把文件路径填写上去。
LiuYuhang
再次尝试后,依旧不行
void Start()
ArcGISMapComponent arcGISMapComponent = FindObjectOfType<ArcGISMapComponent>();
//arcGISMapComponent.Basemap = "file:///storage/emulated/0/GIS/sh_gaode.tpkx";
//arcGISMapComponent.Basemap = "file:///storage/emulated/1/GIS/sh_gaode.tpkx";
arcGISMapComponent.Basemap = "jar:file://" + Application.dataPath + "!/assets/sh_gaode.tpkx";
arcGISMapComponent.BasemapType = BasemapTypes.ImageLayer;
ArcGISLayerInstanceData buildingLayer = new ArcGISLayerInstanceData();
buildingLayer.Name = "Building";
//buildingLayer.Source = "file:///storage/emulated/0/GIS/sh_part.slpk";
//buildingLayer.Source = "file:///storage/emulated/1/GIS/sh_part.slpk";
buildingLayer.Source = "jar:file://" + Application.dataPath + "!/assets/sh_part.slpk";
buildingLayer.Type = LayerTypes.ArcGIS3DObjectSceneLayer;
buildingLayer.Opacity = 1.0f;
buildingLayer.IsVisible = true;
arcGISMapComponent.Layers.Add(buildingLayer);
LiuYuhang
原因暂不清楚
