Hello!
We are in the process of developing an app for travel bloggers. The application allows you to record track/location animation with further video generation. Unfortunately, we are increasingly encountering the error of displaying tiles. On some devices, the tiles start blinking or are simply displayed incorrectly. In this video (attached) you can see how only level 10 detail causes strange behavior when loading the tails. ArcGISViewStateLogging does not produce any errors. You may notice that the FOV is increased (this is needed to capture a large area), turning on the Use Camera View Port setting does not help. BUT! Changing the base map to the one suggested by ArcGis SDK solves the problem. We use our private map, which on has the same base “Imagery” layer and an additional layer for rendering country boundaries.
I have three questions that have accumulated during development:
1. Why can maps be rendered with errors on some devices? (Spatial Reference is set correctly).
2. How do I know the status of tile loading? Video recording should only start when the tiles are fully loaded. I found the only way to know the current status. From the ArcGISRenderer script I subscribe to the custom IsTileLoaded event, but the event only responds to receiving tiles from the north, Unity still needs some time to render the received data - it's a bit more complicated. Maybe there is a simpler way?
3. How to find out the current LOD (0-23)? I was able to determine at what Altitude level the LOD changes but it's still not accurate. ArcGis has an awesome info about it “Zoom levels and scale” but LOD still hasn't been added to the SDK or am I just blind?
I'd appreciate the feedback!
Examples of videos that our application generates:
https://www.youtube.com/watch?v=Zq7SaTlsDaQ&feature=youtu.be
https://www.youtube.com/watch?v=9fufWj_Pco4
https://www.youtube.com/watch?v=Y8Q9mhQUZr8
Cool project!
On a general note, the quality factor is not equal to the LOD level. The LOD levels are loaded automatically based on whether the respective tiles are within the view frustum of ArcGIS Camera Component and how far they are (or more specifically, how large they appear on screen). That means the tiles that are closer to ArcGIS Camera have a higher quality than the ones farther away. I don't believe there is any way to force loading a fixed LOD.
The quality factor manipulates the calculation for this automatic approach. Increasing this values means that farther away tiles are (likely) loaded with a better LOD.
As for the FOV, the values under ArcGIS Camera Component only change the view frustum of this component but not of the actual (viewport) camera. Basically, when you increase this FOV, the plugin will load the content that is not (yet) visible to the (viewport) camera. If you need to increase the capture FOV, you need to change the Camera Component properties.
I am not sure about the artifacts in your video. If it happens only with your private layer, there might be an issue with it. Can you use one of the default basemaps + an additional layer with the country boundaries?
You can track the status of loading the tiles by adding a listener to the DrawStatusChanged event (added in version 1.7)
mapComponent.View.DrawStatusChanged += (ArcGISDrawStatus status) =>
