Hi team,
I am trying to use an open source library to display arcgis vector tiles in my app.
The library specifies authorisation via http auth headers, which should be supported as per docs:
https://developers.arcgis.com/documentation/security-and-authentication/reference/http-header-authen...
I find that this is not the case for some endpoints, eg:
https://basemaps-api.arcgis.com/arcgis/rest/services/World_Basemap_v2/VectorTileServer
It requires an explicit token param.
Can you please check how I can specify auth headers for this endpoint?
Thanks.
On second thought the library may be doing the wrong thing.
I see that initial request to get the tiles url contains the token so that should work without the auth header.
I don't see an option to delete this post.
@msuk1the way to do this is to call the basemap style service with your authentication token in the header as documented here: https://developers.arcgis.com/rest/basemap-styles/arcgis-navigation-style-get/#token
subsequent tile requests should then supply the token. This is typically done with the mapping library. You can review some of the open-source implementations provided on https://developers.arcgis.com/documentation/#open-source-mapping-libraries, Esri Leaflet is a popular one that demonstrates this.
Thanks John, that's what I realised eventually.
The style contains a source field, and the library I amusing was making a subsequent request to the url specified in the source.
There's no obvious reason for it so I have asked the library owner to fix it.
