(Reposting a similar post in this group in case some check this location vs. the ArcGIS Pro location.)
Is anyone aware if ZIP+4 data exists in the Living Atlas, and if not, if you know of other such sources? I'm trying to create a ZIP+4 map of Michigan, as I have seen ZIP+4 maps of other areas, but have had no luck finding any source data. Appreciate any and all help!
Hi Andrew, thank you for your question. I have checked with our internal resources and it appears that we do not currently have a set of ZIP+4 data within ArcGIS Living Atlas or Business Analyst. However, one of our data partners, TomTom, appears to have ZIP+4 options: https://www.adci.com/tomtom-map-data. You should be able to also obtain them from USPS directly: https://postalpro.usps.com/address-quality-solutions/zip-4-product. Hope this helps!
