Why aren't all layers displayed when using MapImageLayer without specifying sublayer? It seemed to work in version 4.4..
384
07-12-2018 09:56 AM
JackFairfield
Occasional Contributor II
In my simple JSBin example, why aren't all layers from my arcgis rest endpoint being shown?
Simple JS bin example
According to the documentation, when adding a MapImageLayer to the map:
A Collection of Sublayer objects that allow you to alter the properties of one or more sublayers of the MapImageLayer. If this property is not specified, all the sublayers from the service are displayed as defined in the service. If an empty array is passed to this property then none of the sublayers from the service are displayed in the layer.
In my example, I am not specifying the sublayers property.  So why aren't all of my layers being included?
I noticed that if you change the ESRI JS API version back to 4.4, it works as expected:
I also inspected the network requests and compared the 4.4 api version to the 4.8 version:
4.4 Request
4.8 Request
For some reason, the "Layers" parameter doesn't seem to be correctly populated in the 4.5-4.8 version of the JS api.
This breaking change in the api wasn't listed in the release notes for js version 4.5.
Release notes for 4.5
Thanks for any help debugging / finding a workaround for this issue.
ReneRubalcava
Frequent Contributor II
It looks like maybe 4.4 was handling it incorrectly.
Looking at the service info, the defaultVisibility of all layers except for "Bikeways" is false, so 4.8 is displaying the layer correctly now.
https://geo.azmag.gov/gismag/rest/services/Test/BikeMap_Test/MapServer?f=pjson
You could iterate over the sublayers and turn them all on if you'd like
JS Bin - Collaborative JavaScript Debugging
You could also use the LayerList to manage the visibility. You can see that the LayerList also picked up the correct visibility of the layers.
Hope that helps, thanks!
ReneRubalcava
JackFairfield
Thanks for the help Rene.  I really appreciate it.
That makes total sense to me.
