WAB - "this" Keyword Conflict with Button Element
441
03-23-2023 04:08 PM
XuanKuai
New Contributor III
I created a button element with an onclick using the following method:
domConstruct.create('button', {
  value: someValue;
  onclick: this.onBtnClick
}, someNode);
The onBtnClick method uses the value of the button element, and also calls another function:
onBtnClick: function() {
  var someVar = this.value;
  this.someFunc();
someFunc: function() {
When executing the onclick, it gives this error:
Uncaught TypeError: this.someFunc is not a function at HTMLButtonElement.onBtnClick
However, the button element's value could be correctly fetched by this.value. So it looks like in the onBtnClick method the this keyword only refers to the button element instead of the entire widget. Is there anyway to use both this.value and this.someFunc in onBtnClick?
KenBuja
MVP Esteemed Contributor
You have to use the hitch function in the dojo/_base/lang module when using "this" in callback functions. Here is how I use in my code to run the function "applyEdits" when clicking on a button
import lang from "dojo/_base/lang";
  "div",
    class: "jimu-btn " + settingName,
    style: "margin-top: 5px; margin-bottom: 5px;",
    onclick: lang.hitch(this, function (evt) {
      this.applyEdits(evt);
  container
KenBuja
  "div",
  container
XuanKuai
New Contributor III
Thank you! This enables me to use the function while also using evt.target.value to access the button's value. And thank you for answering the same question on the other website!
KenBuja
Glad to help you out!
