Using Arcane to set CIMPrimitiveOverride with if statement
136
6
2 weeks ago
ChaosSteve
I am working with primitive overrides to change the image URL of for a feature. I want to set the CIMPictureMarker based on an attribute. Eventually my if statement will grow more complex, but I am starting with a basic change out of the image URL.
I have created a script tag in my HTML to return a different image based on the value of an attribute
<script type="text/javascript" id="serviceTag">
if($feature.open){
return "https://myURL/order-green.png"
}else {
return "https://myURL/order-red.png"
</script>
Then I reference that element and put it into my valueExpressionInfo
const serviceArcade = document.getElementById("serviceTag").text;
const serviceOrderRenderer = {
type: "simple",
symbol: new CIMSymbol({
data: {
type: 'CIMSymbolReference',
primitiveOverrides: [
type: 'CIMPrimitiveOverride',
primitiveName: 'imageColorOverride',
propertyName: 'url',
valueExpressionInfo: {
type: 'CIMExpressionInfo',
expression: serviceArcade,
returnType: 'Default',
symbol: {
type: 'CIMPointSymbol',
primativeName: "imageMarker",
symbolLayers: [
type: "CIMPictureMarker",
enable: true,
It gives me an errors saying ParsingError: Unexpected identifier. Why does it say it cant parse an if statement?
CodyPatterson
MVP Regular Contributor
Hey @ChaosSteve
It may be because the if statements in Arcade are slightly different, would replacing your if statement with this be fruitful?
    return IIf($feature.open, "https://myURL/order-green.png", "https://myURL/order-red.png");
</script>
 Cody
ChaosSteve
It looks like an attribute cannot be a boolean, so I have it set to a string. My new code is
<script type="text/plain" id="serviceOrderTag">
return IIf($feature.open === "true", 'https://myURL/order-green.png',
'https://myURL/order-red.png');
</script>
This is working
KenBuja
MVP Esteemed Contributor
The Arcade samples use the "text/plain" attribute generally with inline scripts and the "text/javascript" attribute with external .js files. Does this fix your parsing error?
<script type="text/plain" id="serviceTag">
        if($feature.open){
        }else {
</script>
ChaosSteve
This was also part of the issue
ChaosSteve
To follow up on this I am trying to add a string builder. It tells me a comma is expected on this formatting. Not sure if there is an issue with checking for null or if arcane has a different way to check
return IIf($feature.ageCategory != null, 'url.com/order-' + $feature.age + '.png', '//url/order-0.png'
ChaosSteve
Missing ending bracket. Fixed
