I wanted to migrate an application to arcgis components and have some trouble with setting a basemap from a WMS.
In the html I create <arcgis-map> component and then wanted to create a BaseMap from a WMSLayer object and set the arcgis-map's basemap property to said BaseMap object. Now I get the following error: [esri.core.accessorSupport.ensureTypes] Accessor#set Assigning an instance of 'esri.Basemap' which is not a subclass of 'esri.Basemap'
Note that I am loading the API (4.31) from a local folder and the componets library through a link ("https://js.arcgis.com/map-components/4.31/arcgis-map-components.esm.js").
I got a similar problem when trying to add a layer to the map through the addLayer function of the map component. I always get this error: esri.WebMap] #add() The item being added is not a Layer or a Promise that resolves to a Layer.
But i guess that's another story.
Thanks in advance.
Greetings,
Marc
Hi Marc - could you share a codepen or snippet that reproduces the issue you are running into?
Here is an example that uses map components with the WMSLayer as the basemap. Hope this helps! https://codepen.io/annefitz/pen/yyBvZQv
