swipe witget on off control
188
6
05-16-2024 04:24 AM
emreaktas1
New Contributor II
hello,
I open the swipe widget with the button function.
How can I turn it back off?
sample code
I want to turn the swipe widget on and off with a button.
JeffreyThompson2
MVP Regular Contributor
I looks like we need to use the destroy() method.
let swipe = null
const swipeButton = document.getElementById('swipeButton')
swipeButton.addEventListener('click', toggleSwipe)
function toggleSwipe(){
   if (swipe) {
      swipe.destroy()
      swipe = null
   } else {
      swipe = new Swipe({
         leadingLayers: [layer],
         trailingLayers: [layerParse1],
         position: 50,
         view: view
      view.ui.add(swipe)
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Swipe.html#destroy
GIS Developer
City of Arlington, Texas
JeffreyThompson2
This should destroy the swipe widget.
view.ui.remove(swipe)
This should hide the swipe widget without destroying it.
swipe.visible = false
I'd use the second one if I want to toggle the swipe back on with the same configuration, as it should be a bit faster than having to re-create the swipe from scratch.
GIS Developer
emreaktas1
New Contributor II
My codes did not work as I wanted.
How can I edit here?
JeffreyThompson2
The way you have defined swipe is scope bound, so you are unable to call it again later. Try something like this.
let swipe = null
   if (swipe) {
      swipe = null
   } else {
      swipe = new Swipe({
         position: 50,
         view: view
      view.ui.add(swipe)
This should make a button that adds the swipe on the first click and removes it on a second click.
GIS Developer
emreaktas1
New Contributor II
On the second click the swipe widget was not removed completely.
It just works invisibly
JeffreyThompson2
let swipe = null
   if (swipe) {
      swipe.destroy()
      swipe = null
   } else {
      swipe = new Swipe({
         position: 50,
         view: view
      view.ui.add(swipe)
GIS Developer
emreaktas1
New Contributor II
Yes, this is the destroy() method. it worked😍
