Resize widget (API 4.x)
876
01-31-2022 03:24 AM
ZA1
* I am struggling to resize the editor widget.
* The Feature Selection window in "Create" workflow is too small:
* The scroll list for the feature layers needs to be longer, to display more features
* These CSS classes seem to be responsible for the size of the feature selection window
.esri-item-list"
esri-item-list__scroller
However, when I try to change the height of these elements. The height of the Feature Selection does not change.
 watchUtils.when(editor, "activeWorkflow", (x) => {
                if (x.type == "create") {
                    setTimeout(function(){
                        // Get html element
                        let e1 = Array.from(document.getElementsByClassName("esri-item-list"))[0];
                        let e2 = Array.from(document.getElementsByClassName("esri-item-list__scroller"))[0];
                        // Change Height
                        e1.style.height= "300px";
                        e2.style.height= "300px";
                    },500);
Your help will be greatly appreciated!
ReneRubalcava
Looked like this worked.
.esri-ui .esri-editor .esri-item-list__scroller {
  max-height: 500px; /**whatever you want here**/
ReneRubalcava
ZA1
It works! thank you so much. I thought I tried that already '😂 appreciated
