Rendering a point is not working for WebMap
134
a month ago
JoelCabreraRendón
Hello. I'm trying to render a saved location(using a point graphic) into a web map. But it is not working. The point is never rendered.
I tried following the guide at https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=intro-graphics with no success. I also tried using the react components.
See https://codepen.io/Joel-Cabrera/pen/bGyvMKO for an example of that.
ReneRubalcava
Frequent Contributor II
If you wrap most of your code in a view.when, you can use the views spatial reference to create your point.
 const point = new Point({
    x: -9810308.361037346,
    y: 5136801.597252877,
    spatialReference: view.spatialReference
The default spatial reference of geometries is WGS84, so you need to specify when using something else.
ReneRubalcava
