I am currently working with the the ArcGIS API for JavaScript. I dived into the ArcGIS API for JavaScript currently for just a month now , so I am not that familiar with it.
is there a way to select the different layers of a 3D webscene with the js esri api? like a drop down menu or similar on the side where i can select the layers that i want to show.
Solved! Go to Solution.
Hi Ruben, the simplest way to achieve what you describe ("select the layers that I want to show") is to use the LayerList widget provided as part of the API. This sample shows how it can be integrated into your app.
