JimuMapView will not zoom
314
10
05-17-2024 05:23 AM
AngelaSchirck
Hi all,
I'm creating a widget and want it to zoom to a particular lat/lon.  All functionality of the widgit works great except the zoom.  It will pan to the point but not zoom in no matter what zoom level I put. There are no zoom restrictions on the map itself, whatever zoom level the map is in, it stays at and pans to the point.  I've tried several different ways to do this, here is my latest relevant code.  Here mapViewRef refers to a JimuMapView instance.
const searchAndZoomToLocation = () => {
    if (mapViewRef.current && inputLatitude && inputLongitude) {
      const lat = parseFloat(inputLatitude);
      const lon = parseFloat(inputLongitude);
      if (!isNaN(lat) && !isNaN(lon)) {
        // Add point to the specified location
        const point = new Point({
          longitude: lon,
          latitude: lat
        const pointGraphic = new Graphic({
          geometry: point,
          symbol: pointSymbol.current
        mapViewRef.current.view.goTo({target: point, zoom: 14}); // Zoom to point
        mapViewRef.current.view.graphics.removeAll(); // Remove existing graphics
        mapViewRef.current.view.graphics.add(pointGraphic);
Any ideas why this only pans and doesn't zoom? What ever number I set zoom to, it doesn't change the result.
2 Solutions
JeffreyThompson2
MVP Regular Contributor
Is it possible your basemap does not have defined LODs (zoom levels)? What happens if you replace the zoom property with the scale property?
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#GoToTarget2D
GIS Developer
City of Arlington, Texas
AngelaSchirck
Okay, solved my own problem....
Instead of setting mapViewRef.current.view.zoom = 14; I used mapViewRef.current.view.scale = 1000; and it now zooms to the point.
emreaktas1
specific zoom and you can place the map within specific geographic coordinates
const view = new MapView({
        container: "viewDiv",
        map: map,
        center: [latitude ,longitude ],
        zoom: 12,
        constraints: {
          geometry: {
            type: "extent",
             xmin: 3269655.5200,
             ymin: 4780511.2100,
             xmax: 3296867.1000,
             ymax: 4810818.4900,
            spatialReference: {
              wkid: 102100
          minZoom: 11,
          maxZoom:20,
          rotationEnabled:false,
AngelaSchirck
Thanks, but didn't help, still panning not zooming.
emreaktas1
Hello
How can I get the entered text value with searchWidget?
JeffreyThompson2
Have you tried re-ordering your functions? See what happens if you call goTo() after the add().
GIS Developer
emreaktas1
Hİ @JeffreyThompson2
Hello
AngelaSchirck
Your question is vague and not an answer to this post, please start a new thread with your question.
AngelaSchirck
Yes, I also recently tried "goTo" THEN zoom but it STILL won't zoom:
      if (!isNaN(lat) && !isNaN(lon) && isValidCoordinate(lat, lon)) {
          longitude: lon,
          latitude: lat
          geometry: point,
        mapViewRef.current.view.goTo({ target: point }).then(() => {
JeffreyThompson2
GIS Developer
AngelaSchirck
Oh, wow, I actually did that and it worked, but I didn't see this post until after!  Thanks!
