How to filter out features with WHERE clause
222
11-17-2021 11:27 AM
REDARiahi
I'm trying to filter out features with Departamento = '01 - País' using the WHERE clause, using "!=", but it returns "Invalid Syntax". Here is the REST API url and this is the WHERE clause statement I'm using:
WHERE = FECHA>=CURRENT_TIMESTAMP - INTERVAL '10' DAY
AND Departamento != '01 - País'
 The syntax is valid with "=", but not with "!=".
Thanks for the help!
jcarlson
MVP Honored Contributor
"Not equals" should be "<>".
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
REDARiahi
Thanks Josh, didn't think about that one! I was mislead by the documentation stating that "!=" was an accepted syntax. I'm I understanding it wrong?
jcarlson
I'd bet it's this sentence here:
Some data sources have restrictions on what is supported.
That's in reference to which SQL-92 commands are acceptable in the where parameter. I'd take a closer look at the data source you're querying and what kind of database it's running on, as that may be what's causing the issue.
- Josh Carlson
Kendall County GIS
