Graphic IMAGES are not displayed correctly
551
01-06-2022 01:41 AM
MichaelK1
New Contributor III
Hi!
Issue: Images are not fully drawn. Why?
Should I change the underlying tile layer?
My renderer:
type: 'CIMSymbolReference',
symbol: {
type: 'CIMPointSymbol',
symbolLayers: [
type: 'CIMPictureMarker',
enable: true,
scaleX: 1,
textureFilter: 'Picture',
tintColor: [255, 255, 255, 255],
url: 'data:image/png;base64,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',
Thanks!
AnneFitz
Hi @MichaelK1 - thanks for pointing this out. This might be a bug on our end. What layer are you using to render these features?
MichaelK1
New Contributor III
Hi! I'm using a feature layer with CIM symbol picture marker. It looks like the tiles from the base map are overlapping the images.
Thanks in advance!
AnneFitz
We've fixed this bug for the 4.23 release. You can test out the fix ahead of time using our development CDN https://js.arcgis.com/next/
Let me know if you are still seeing any issues! Thanks.
