I have some ideas. Can I do something to dynamically set a custom highlighted background color for some rows in the table?
For example:all rows with an update table field value of 1 are set to green background.
I have achieved this effect!
I read about vaadin ui document, the framework that the table relies on, which provides a method to customize the table color.
look code:
this.viewFeatureTable.when().then(table => {
setTimeout(() => {
let style = document.createElement('style');
style.textContent = `
.tb-row-add {
background: rgba(54,173,71,0.3);
.tb-row-update {
background: rgba(1,122,194,0.3);
const ref = document.getElementsByTagName('vaadin-grid')[0];
ref.shadowRoot?.appendChild(style);
(this.viewFeatureTable as any).grid._grid.cellClassNameGenerator = (column: any, model: any) => {
let classes = '';
if (model && model.item) {
classes += column.path;
const item = model.item;
if (item.feature.attributes.update_type === 'add') {
classes += ' tb-row-add';
} else if (item.feature.attributes.update_type === 'update') {
classes += ' tb-row-update';
return classes;
}, 1000);
this.tableToolsService.viewFeatureTable$.next(table);
look code:
setTimeout(() => {
.tb-row-add {
.tb-row-update {
let classes = '';
return classes;
}, 1000);
