Disable scaling feature in Editor widget
253
a month ago
achyl
Hi, how can i disable scaling in editor widget?
I would like to disable scaling for CityFurnitureLayer when creating and updating.
const editor = new Editor({
  view: view,
  layerInfos: [
    CityFurnitureInfos(CityFurnitureLayer, content),
    VegetationInfos(VegetationLayer, content),
    BaseInfos(BaseLayer, content),
    PathInfos(pathLayer, content),
  tooltipOptions: { enabled: true },
  labelOptions: { enabled: true }
export const CityFurnitureInfos = (CityFurnitureLayer, content) => {
  return {
    layer: CityFurnitureLayer,
    formTemplate: {
      elements: [
          type: 'field',
          fieldName: 'TYPE',
          label: content.furnitureInfos.labelType
          type: 'field',
          fieldName: 'SIZE',
          label: content.furnitureInfos.labelSize,
          formatter: function (value) {
                return value.toFixed(2);
              format: {
                places: 2,
                digitSeparator: true
              editorType: 'number'
          type: 'field',
          fieldName: 'ROTATION',
          label: content.furnitureInfos.labelRotation,
    fieldInfos:  [{
        fieldName: 'SIZE',
        format: {
          places: 2,
JoelBennett
MVP Regular Contributor
You can disable scaling on updates like so:
editor.viewModel.sketchViewModel.defaultUpdateOptions.enableScaling = false;
Unfortunately, the defaultCreateOptions provide no such property.   They do have a preserveAspectRatio property though which may be helpful, as does defaultUpdateOptions:
editor.viewModel.sketchViewModel.defaultCreateOptions.preserveAspectRatio = false;
achyl
It didn't work,
I set this property in editor.when(), but when I create a new object, this property is overwritten
Jan62
We have the same problem. It seems, only 4.29 is affectet under 4.28 it works fine. The the Sandbox Code.
4.28 Works as intended
<html lang="en">
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Edit features with the Editor widget | Sample | ArcGIS Maps SDK for JavaScript 4.29</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.29/esri/themes/light/main.css" />
  <script src="https://js.arcgis.com/4.28/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
        "esri/WebMap",
        "esri/views/MapView",
        "esri/widgets/Editor"
        WebMap, MapView,
        Editor
        // Create a map from the referenced webmap item id
        const webmap = new WebMap({
          portalItem: {
        const view = new MapView({
          container: "viewDiv",
          map: webmap
        view.when(() => {
            view: view,
          editor.viewModel.sketchViewModel.defaultUpdateOptions.enableRotation  = true;
          editor.viewModel.sketchViewModel.defaultUpdateOptions.enableZ  = false;
          editor.viewModel.sketchViewModel.defaultUpdateOptions.multipleSelectionEnabled = false;
          editor.viewModel.sketchViewModel.defaultUpdateOptions.preserveAspectRatio  = true;
          editor.viewModel.sketchViewModel.defaultUpdateOptions.toggleToolOnClick = false;
          editor.viewModel.sketchViewModel.tool = "transform";
          // Add the widget to the view
          view.ui.add(editor, "top-right");
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
4.29 Overrides the defaults and enables scaling
<html lang="en">
<head>
  <script src="https://js.arcgis.com/4.29/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
        "esri/WebMap",
        WebMap, MapView,
        Editor
          portalItem: {
          map: webmap
        view.when(() => {
            view: view,
  </script>
</head>
<body>
</body>
</html>
achyl
Thank you,
after downgrading version it works, but only for 2D objects, I can't lock the scaling of a point-3d type symbol.
