ArcGIS for Javascript on ASP.NET Core project
959
01-06-2022 03:41 AM
MeloiMagpantay
Is there a way to use ArcGIS Javascript on ASP.NET Core website. I've been trying to use it but it is causing an error like this.
I tried to follow the get started documentation.
ReneRubalcava
Well, I haven't used ASP in years, so I spun up a new project locally and it looks like the default app uses a local jquery and bootstrap. This is where the error comes from because jquery has a require method it uses. We can work around this in the "Pages/Shared/_Layout.cshtml" file with a dojoConfig to define where the local packages can be loaded from.
<script>
    var dojoConfig = {
    packages: [
        location: location.pathname.replace(/\/[^/]+$/, "") + "lib/jquery/dist",
        main: "jquery.min",
            location.pathname.replace(/\/[^/]+$/, "") + "lib/bootstrap/dist/js",
        main: "bootstrap.bundle.min",
</script>
<script src="https://js.arcgis.com/4.22/"></script>
Then in your "wwwroot/js/site.js" file, when you load the JSAPI and require the modules, you can load the jquery and bootstrap stuff.
require([
  "esri/WebMap",
  "esri/views/MapView",
  "jquery",
  "bootstrap"
], function (...) {...})
This fixed the issue in my local app, should fix the issue for you too. Now I feel like I should do something with dotnet...
NadirHussain1
where should i write the code for map load code.in site.js. write the code like below.
function showMap() {
require([
"esri/config",
"esri/Map",
"esri/layers/FeatureLayer",
"jquery",
"bootstrap"
], function (esriConfig, Map, MapView, FeatureLayer) {
const map = new Map({ basemap: "arcgis-topographic" });
const view = new MapView({
container: "viewDiv",
map: map,
center: [-118.80543, 34.02700],
zoom: 13
//Trailheads feature layer (points)
const trailheadsLayer = new FeatureLayer({
url: "https://services3.arcgis.com/GVgbJbqm8hXASVYi/arcgis/rest/services/Trailheads/FeatureServer/0"
map.add(trailheadsLayer);
//Trails feature layer (lines)
const trailsLayer = new FeatureLayer({
url: "https://services3.arcgis.com/GVgbJbqm8hXASVYi/arcgis/rest/services/Trails/FeatureServer/0"
map.add(trailsLayer, 0);
but i did not see any map on index page and there is no error in console.actually i  cant understand where should i call showMap function.Please help.
Thanks
sajalpal
We are also getting the same issue. While we are using the version "https://js.arcgis.com/4.26/".
Did you find any fix for this
Thanks.
GavinBoyd
New Contributor II
The way to get around this error is to comment out this section of your shared _layout.cshtml view
<script src="~/lib/jquery/dist/jquery.min.js"></script>
<script src="~/lib/bootstrap/dist/js/bootstrap.bundle.min.js"></script>
<script src="~/js/site.js" asp-append-version="true"></script>
@RenderSection("Scripts", required: false)
It appears to conflict with any arcgis sdk of higher than 4.15
