add image in featuretable grid
609
12-07-2018 08:02 AM
MRReddy
i was trying to add image same as above pic in feature table and on row-select zoom to point
below is my code for featuretable i tried to add image for objectid
Any suggestions
 var myFeatureTable = new FeatureTable({
        featureLayer: layerdata,
        map: map,
        editable: false,
        dateOptions: {
            datePattern: 'M/d/y',
            timeEnabled: true,
            timePattern: 'H:mm',
        syncSelection: true,
        showRelatedRecords: true,
        showAttachments: true,
        fieldInfos: [
        alias: 'Zoom to Location',
        //formatter: makeZoomButton('${objectid}')
        menuFunctions: [
        outFields: ["*"],
    }, 'myTableNode');
    myFeatureTable.startup();‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
 function makeZoomButton(id) {
        //set the feature 'id' as the alt value for the image so that it can be used to query below
        var zBtn = "<div data-dojo-type='dijit/form/Button'><img src='ZoomIn.png' alt='" + id + "'";
        zBtn = zBtn + " width='18' height='18'></div>";
        return zBtn;
RobertScheitlin__GISP
Malla,
  NOT an easy task, but here is some guidance:
fieldInfos
  alias: ' ',
  editable: false,
  format: {
    template: '<span class="esri-icon-zoom-in-magnifying-glass"></span>'
next
myFeatureTable.on("load", function(evt){
  myFeatureTable.grid.on("td.field-OBJECTID:click", function(evt){
    var OID = myFeatureTable.selectedRows[0].OBJECTID;
    //Do your zoom event stuff here
I can't do all the coding for you, but this will get you started.
Malla,
fieldInfos
  alias: ' ',
  editable: false,
  format: {
next
MRReddy
Thanks Robert, it worked
ImtiyazPasha
How to implement same(add image in featuretable grid)
in ArcGIS API for js 4. x FeaturerTable widget, please suggest.
