Hi, I am new of InstantApp and I am replacing an interactive map from Experience Builder to InstantApp.
I've done a lot of research on the web, Esri blog, etc, but I haven't found an answer to the following question.
Is it possible to add a category list or domine in the search widget?
I have a map with feature classes
I want to search for a field of a feature class providing suggestion to the user according to a domains or a category list.
I found 'Create suggestion Template' in such a documentation
https://doc.arcgis.com/en/arcgis-online/create-maps/configure-search-in-apps.htm
but when I enable suggestion the only options I find are:
- Minimum suggested characters
- Maximum suggestions
- Maximum result
and not 'Template' as explained in the Documentation above.
