Plots not picking up some categorical values
210
06-07-2022 09:27 AM
Ed_
by MVP Regular Contributor
Good day all,
I am trying to create some plots from a text column which has categorical values. Now when I add a filter for this column, the filter does pickup every value as shown below:
However, the plot is only picking up `levee` and `No Data` which is an odd behavior.
Every categorical value in the adapt_type column has a value in the `LY_JUST` column. Even the snapshot of the datatable shows that for example adaptation type `valve` has `LY_JUSTVAL`.
How can I fix this?
Scott_Aulen
@Ed_,
Do you have two values being displayed on the x value? It appears you're plotting {adapt_type} and {floodfactor} which I think would affect the results.
