Defining coded value domains
249
08-22-2023 08:34 AM
bsklaohfl
I have a coded value domain for a field called asset owner, from -1 to -7. Which function would I use to define each value with a string. Example, -1 = Private, -2 = Other, etc etc.
Thank you.
2 Solutions
Ian_Muehlenhaus
Hi bsklaohfl,
I believe you would:
* Show Table
* Add Field
* Then type:
IF(codedFieldName=-1,”Private”,IF(codedFieldName=-2,”Other”,IF(codedFieldName=-3,”Other2”,IF(codedFieldName=-4,”Other3”,IF(codedFieldName=-5,”Other4”,IF(codedFieldName=-5, “Other5”, IF(codedFieldName=-6,”Other6”, IF(codedFieldName=-7,”LastOther”, “Unknown”))))))))
I haven’t checked this, so apologies for a typo. But basically, you can write an IF function using the above syntax. It will go through and anything with a -x number will be given the corresponding text (e.g., “Other5”). If one of the values isn’t listed, it will be given “Unknown” – see the last value and change it to whatever you want.
Better yet? I recommend downloading ArcGIS Insights Desktop. Open your data in the Data Engineering tool. Go to the field and select CHANGE DATA TYPE to String. Then do a FIND AND REPLACE on the field and replace every value with your preferred text. Very convenient in Data Engineering in Desktop version.
I hope this helps! Sorry if I misinterpreted your question. And thank you for using ArcGIS Insights!
Ian
Ian Muehlenhaus
Location Analytics
bsklaohfl
Hi @Ian_Muehlenhaus ,
That worked! Thank you. I knew there had to be a way, thank you so much for your helpful response. I also installed ArcGIS Insights for Desktop - I didn't know it existed...ha! In case anyone is looking for something similar, here is the formula I used to calculate my asset ownership field:
IF(OWNEDBY=-1,"Private",IF(OWNEDBY=-2,"Other",IF(OWNEDBY=1,"County",IF(OWNEDBY=-3,"HOA",IF(OWNEDBY=-4,"State",IF(OWNEDBY=-5,"Parks and Rec Dept",IF(OWNEDBY=-6,"City of St. Augustine",IF(OWNEDBY=-7,"Contractor"))))))))
Ian_Muehlenhaus
Hi bsklaohfl,
* Show Table
* Add Field
* Then type:
Ian
Ian Muehlenhaus
Location Analytics
bsklaohfl
Ian_Muehlenhaus
So happy it helped, @bsklaohfl! Woohoo!!!
Thanks for sharing the code you used.
Yes, the IF statement comes in very, very handy! 🙂  Once you use it once, there's no going back! 😉
Thank you for using ArcGIS Insights! All the best on your project!
Ian
Ian Muehlenhaus
Location Analytics
LauraBecht
Hi, you basically create a new field and calculate an if statement, so IF(asset owner = -1, 'Private', IF(asset owner = -2,'Other',...,default). Should get your coded values.
Regards,
Laura Becht
