Added Datasets Don't Appear in Insights
671
11-22-2022 07:07 AM
ZachBodenner
MVP Regular Contributor
Hello,
Very new to Insights, still playing around. I added some Datasets via the New Dataset button but they don't actually appear there once uploaded. I can tell that they've been added; the below picture shows that I actually tried to add them multiple times since they didn't show up. you can also see that I have an Insights Workbook as an item in AGOL:
However, my Datasets and Workbooks tab remain empty:
Interestingly, the home tab shows my workbooks, but no data:
Is there something going on here that I'm not understanding? I created the dataset and it's shared with the whole org. so I am not quite sure why it wouldn't show up.
ZachBodenner
Thanks Scott for helping me out! The Workbooks and Datasets tab default to items shared with me. Since I created the items and stopped there, they weren't technically shared with me, so just changing that selection to organization or my items does the trick:
Scott_Aulen
@ZachBodenner,
 A couple questions to help troubleshoot your issue:
1. You're using Insights in ArcGIS Online, correct?
2. Do you have publisher privileges on your AGO user account?
3. When you click on the Workbook or Dataset tab does the developer console show any errors?
ZachBodenner
1. That's correct, though ultimately I'll be using it primarily in Enterprise. Currently giving it the 21-day test drive.
2. Yeah, this is our admin account.
3. No, no errors shown.
Scott_Aulen
That's quite odd. What happens if you try to open one of the workbooks from the homepage? I'm happy to schedule a call to walk through the issue if needed.
ZachBodenner
It opens up fine from the home page. We could certainly do a call. Do you want to send me a PM to set that up?
ZachBodenner
