Hub Site custom header html/css - navbar not highlighting the selected tab
378
09-13-2023 05:50 AM
DarrenLloyd__DOIT
New Contributor III
I need help with the navbar holding a selection. I am using the custom header (html/css), most of which was auto-populated with the hub site. When I click on the navbar items they are highlighted with a white bar underneath. However when you click off of the item the white bar disappears. How can I have the item stay highlighted with the white bar when selected?
Tags (4)
KlaraSchmitt
KlaraSchmitt
@DarrenLloyd__DOIT
You may find this post I made helpful for how to manage active states with a custom header: https://community.esri.com/t5/arcgis-hub-documents/tips-showing-active-page-in-a-custom-header/ta-p/...
DarrenLloyd__DOIT
New Contributor III
Not being able to use JavaScript was an issue however this solution worked for me. Thank you @KlaraSchmitt
