I noticed after the recent update to Hub with the font size change that the color of the font inside my search card changed. Now, it's white like the background and only if you hover over the previously searched words can you read what is there. I did not have any custom colors set up so I don't know where the option to change this is. I thought this was part of the default font color.
In this image below, "land use" only appears when my mouse is hovering over it. I assume the default changed to white somehow which matches the background.
Hi @SaraKidd & @Kevin_Peel!
This theming issue should be resolved now, apologies for the inconvenience! Let us know if you're still seeing any odd theming issues with your search cards.
Hi @SaraKidd -- thanks for raising this, looks like theme values may be getting mixed up. We'll look into it and get a fix out!
Great, thanks for the quick response!
Seems to be a common issue - also experiencing on our own Hub and can replicate on other hubs as well.
Hi @SydneyBohn - just noticed that it works again just before you posted this update! Everything's back to normal and works fine. Thanks
Everything looks good here. Thanks for moving quickly on this!
