Is anyone else noticing this issue? I have been noticing feature services (datasets) on hub sites are not displaying the full scope of available dates within the dataset (Min/Max). Instead it is showing some arbitrary number in or around 2021. I can however, edit the maximum date and push it to a recent 2022 date and the data shows up as expected.
The filter min/max date is showing a max of 6/30/2021 even though the max in the reported data is 12/29/2021.
Hi @John_Spence thanks for posting your question. It looks like this was caused by a stale cache of the dataset's attribute statistics (when initially harvested 6/30/2021 was the max, service had updates to 12/29/2021, but cache wasn't updated yet).
I've confirmed the filter and table show the correct dates, once the dataset is reharvested the helper text should reappear with the correct min/max values. You can manually kick off a reharvest for the dataset by visiting the dataset's metadata editor in ArcGIS Hub and selecting ••• (next to "Save") and "Check for Item Updates".
Apologies for the issue!
That is a great to know you can get things like that to update via Hub! Appreciate the support and for taking a look at it.
