Certificate renewal failed for Hub site configured with custom domain
521
09-23-2022 07:31 PM
Yann-EricBoyeau
One of our customer experiences certificate expiration for its open data Hub site.
The Hub site is configured with custom domain https://data.noumea.nc/ and it worked flawlessly for 2 years.
The certificate expired 9 days ago and we have no way to configure its renewal.
May the ArcGIS Hub team fix the issue ?
https://doc.arcgis.com/en/hub/sites/fix-a-problem.htm
Thank you
SydneyBohn
Hi @Yann-EricBoyeau!
Certificate renewals should occur automatically so the behavior you're seeing is not something we would expect. Are you able to open a case with Esri Support? They would be able to help investigate the issue further. Details for contacting Support can be found here: https://support.esri.com/en/contact-tech-support
Regards,
Sydney
