There are two components for creating a custom header for your site. There is an HTML card that you can edit in the page layout and a CSS text area in the header settings sidebar.
The custom header HTML card supports a limited set of HTML tags:
<a>
<b>
<blockquote>
<br>
<caption>
<cite>
<code>
<col>
<colgroup>
<dd>
<dl>
<dt>
<em>
<h1>
<h2>
<h3>
<h4>
<h5>
<h6>
<i>
<img>
<li>
<ol>
<p>
<pre>
<q>
<small>
<strike>
<strong>
<sub>
<sup>
<table>
<tbody>
<td>
<tfoot>
<th>
<thead>
<tr>
<u>
<ul>
<center>
<style>
<div>
<spa>
<nav>
These can be used in conjunction with many documented Bootstrap classes.
Frequently used classes include:
class | use |
.pull-right | Position elements by floating them to the right of the page |
.pull-left | Position elements by floating them to the left of the page |
.clearfix | Use on a |
.center-block | Center block-level elements |
.text-left | Left-align text |
.text-right | Right-align text |
.text-center | Center-align text |
Presently, we do not support Javascript embedded in the header HTML section. Script tags will be ignored by our compiler. We do intend to add limited Bootstrap Javascript support to allow dropdown menus in navigation and collapsable mobile navigation in a future iteration of our product.
Supported attributes that can be used in conjunction with the <a>
tag:
aria-label class href role src style target
Supported attributes that can be used in conjunction with the <img>
tag:
align alt aria-label class height role src title width
Supported attributes that can be used to support accessibility:
alt aria-label role
Supported attributes supported on any of the the allowed HTML tags:
aria-label class role style
To get you started in adding your own custom header CSS, we have pre-populated the CSS text box in the settings with a few key classes you might want to use if you are working with the default custom header:
class | use |
.custom-header | Wraps the entire component - you can only style tags within this class |
.first-tier | First level of navigation, including the site logo |
.second-tier | Second level of navigation |
Like our custom header, our custom footer is made up of two components, an HTML editing card in the page layout and a CSS text input box under the sidebar settings.
Please read the supported tags and attributes in the custom header above for best practices. The only additional classes of importance found in the footer are related to layout: .container
and .col-xs-12
classes. These are part of the Bootstrap grid structure and are necessary to constrain columns within a fixed width page layout. You may modify the columns as you wish. These classes were not necessary in the header as the Bootstrap <nav>
classes take care of all of this for you in regards to navigation.
