Importing geospatial geofence feature layer to GeoEvent
662
07-19-2022 01:51 AM
PetterHersinger
New Contributor II
I want to import a GeoFence to GeoEvent from my Enterprise portal. In my portal, the feature layer contains a polygon layer. This can, according to GeoEvent not be imported as a GeoFence because I cant choose the Poly-layer in the menu for "layer" in GeoEvent.
Error code: "Unable to import GeoFences with current query: please check and try again".
What format does my file need to be? Or what am I doing wrong? I need to get the layer into GeoEvent as a GeoFence.
Any help with instructions how to import a GeoFence to GeoEvent would be appreciated.
PetterHersinger
New Contributor II
Please help! 🙂
JeffSilberberg
Occasional Contributor III
Maybe look at this other posting -- Not sure but I think you are asking the same basic question.
https://community.esri.com/t5/arcgis-geoevent-server-questions/how-to-import-geofence-to-geoevent/m-...
GarrettMelvin
New Contributor III
Did you make sure to include a query definition on the import screen?  If you want to import all features in a layer, use the expression 1=1.
DanielMurillo
Hello @PetterHersinger Did you ever found a solution to the issue?
