How to import geofence to GeoEvent
167
07-19-2022 12:44 AM
ElviraForslund
New Contributor II
I want to import a geofence to GeoEvent, in what format should the geometry be so that this is possible? I currently have a published feature layer on my Enterprise Portal that contains a Polygon layer. This cannot be imported as a geofence since I am unable to choose the Polygon layer in the drop down bar for "Layer" in GeoEvent and I receive the error  "Unable to import GeoFences with current query; please check and try again".
I have tried different formats for layers to import but have not been successful with any. Any help with instructions how to import a geofence would be appreciated.
Thank you in advance.
ElviraForslund
New Contributor II
Hi, thank you for the reply.
I had follow the latter link you sent and attempted to solve it using workaround 2 without success. Since the post indicated workaround 2 would be successful without the first one, and the post regarded a different error, I did not think to try both. But I tried it now and it worked. So the solution was workaround 1.
Thank you again!
