Filtering various geofences with regex in GeoTagger (GeoEvent)
584
05-20-2022 11:23 AM
AlanDiaz
Hi everybody:
I got an issue, i would like to use in GeoEvent, the processor GeoTagger, but in the geofence(s) I would like to use 3 geofences from 4 available.
this is the tooltip in the field geofences. Maybe isn´t supported all regex.
I have mark with red the field where the regex it goes.
With the example below, doesn't work.
Have any suggestion?
Tags (3)
AlanDiaz
My understanding is that you cannot do what I am trying to do, the scope of regular expressions in that field are limited to the use of "*" or another character, not a complex expression.
So in my case, I changed the logic, and I had to use a field calculator and a field enricher.
GeoEvent version: 10.8.1
AlanDiaz
GarrettMelvin
I have been able to include multiple geofence categories in the same geotagger processor.  Try to group your geofence category descriptions before the / and use an OR character in-between each category.  Format like "Category1|Category2|Category3/.*"  I believe based on your category names it would be:
Critica|Control|Red Vial/.*
I am not certain if the space in Red Vial will have any impact.  Hope this helps.
AlanDiaz
Thanks.
I will try this option.
