Error appears in the reference layer
214
01-15-2024 06:39 AM
GilsonAlbertoRosaLima
I am having difficulty publishing an ESRI map using Power BI.
I go to validate the map and an error appears in the reference layer.
Can you help me find out how to resolve the error?
Tags (1)
CodyPatterson
Occasional Contributor III
Hey @GilsonAlbertoRosaLima
I was curious if you could reply with what the error looks like or the contents? I'm familiar with Power BI and the suite interaction, I'll definitely try to help!
Cody
LeslieUK
Hi @GilsonAlbertoRosaLima
Are the reference layers shared publicly in ArcGIS Online?  I would advise just checking your map has met the requirements found here: Publish a map-enabled report to the web—ArcGIS for Microsoft 365 | Documentation
~Just trying to fix things~
