ArcGIS for Power BI Questions
97
2.6M
423
In Product Plan | I'd like if it was possible to turn off more menu's/options in the Maps menu. Currently you can toggle on/off a few o... by YannickM New Contributor II 3 1 | 3 | 1 | |
Open | So recently we came across an issue where the ESRI for PBI desktop plug in was having trouble geocoding addresses bot... by Ed_ MVP Regular Contributor 5 0 | 5 | 0 | |
Already Offered | When using PowerBI with the ArcGIS Maps for Power BI add-on, adding a dataset to the map allows the user to select th... by DonaldMarutaNHS New Contributor II 2 2 | 2 | 2 | |
In Product Plan | I've seen other ideas asking for the ability to remove Lat/Long from tooltips, format tooltips, etc. when mapping wit... by JCable New Contributor II 4 1 | 4 | 1 | |
Open | Hey everyone,I used PowerBi's arcgis feature to build some maps. Now I would like to directly import those maps into ... by elliot4 New Contributor II 1 1 | 1 | 1 | |
Open | Hi, I have been searching a way to read/load gdb feature table directly from ArcGIS Online into PowerBI/Excel.Can it ... by JulioAAlmeida New Contributor II 0 1 | 0 | 1 | |
Open | Power BI has many out of the box connectors to bring data from external sources (ex. Salesforce) into their data mode... by AndrewRudin1 Occasional Contributor II 5 0 | 5 | 0 | |
Open | Ethiopia is not currently supported as a target country; the woredas are not recognized correctly in the Power BI vis... by AlexAddison New Contributor II 0 1 | 0 | 1 | |
Open | It would be great if we could drop a "Shape" field into the Location well that contains different geometry types. Rig... by JoeEastman1 New Contributor II 2 1 | 2 | 1 | |
Open | Hi, I have a report that has a common filter (page level) and a map on 3 different pages. Let's say the map's defaul... by DonTaggart1 New Contributor 0 2 | 0 | 2 | |
Open | When using boundary polygons, having the ability to have one label appear for each respective polygon as opposed to r... by Bow_Morris New Contributor II 0 0 | 0 | 0 | |
Open | Could be interesting that I could use my shapes with a basemap behind in Power BI. by Constantino New Contributor II 0 0 | 0 | 0 | |
Open | It would be great if we could use Arcade or some other language to customize tooltips, filters, symbology, and other ... by KevinDunlop Occasional Contributor III 0 0 | 0 | 0 | |
Open | It would be great to be able to visualize 3D web scenes in Power BI just like reference layers. I have web scenes wi... by sri_krishnahari New Contributor II 2 0 | 2 | 0 | |
Open | I would love to see this visual support more than one Data Layer. I know we can connect layers that exist in ArcGIS ... by JeffreyKruse New Contributor II 3 0 | 3 | 0 |
Idea Submission Guidelines
