trouble shoot action failed - when a record is updated in a feature layer/Fetch updates, changes or deletions from feature layer
839
10
09-13-2023 05:15 AM
SarahRijneke
I've been struggling to get my flow working properly for a while now. I made some edits the other day and it seemed to be working but when I logged in this morning I see that my flow failed. I'm not exactly sure where or why especially since the results of my condition were true.
I see all kinds of red under the the Apply to each actions. I have never changed the values in those fields so don't understand why it has suddenly stopped working. Any ideas?
AnthonyLatini
@ahargreaves_FW - Yes! This fix is currently under investigation. We are hoping to get to the bottom of this issue as quickly as possible. It's been a tricky one! Once we have an update, I will update this thread as well as make a new post on the main page.
Thank you for your patience on this one!
ahargreaves_FW
Occasional Contributor III
Here's my flow that is similar and works as expected.
can you show a screenshot of the 'raw input' for your condition?
SarahRijneke
This is for one that should have failed (Status:3, Workorderid:null)
This one should have triggered an email (status:3, Workorderid: is not equal to null)
AnthonyLatini
Hi @SarahRijneke - following up on this issue. Are you still experiencing this issue or did this get resolved? Please let me know!
SarahRijneke
I am still experiencing this issue. I never get emails the first time the data is updated anymore (i.e. when the field worker changes the status to Completed). I saw 5 emails come through the other week when I bulk updated a field that was empty (8300+ records). When I query the table to match the conditions in my flow on the day that I updated the data I see that I should have received 227 emails.
ahargreaves_FW
Since the AGOL update on 10/25/23 we've experienced poor Power Automate performance with Triggers sometimes failing for reasons we can't pinpoint. Like @SarahRijneke we bulk update the FeatureService via a shared collaboration which should trigger emails but often doens't.
AnthonyLatini
Thank you for the updates @SarahRijneke and @ahargreaves_FW . My colleagues and I are investigating a number of issues related to fetching updates and triggers. We are unsure at the moment if this is being caused by something in Power Automate or in ArcGIS Online itself.
I will keep this thread posted once I have a better understanding of the underlying issue. Thank you for your patience!
ahargreaves_FW
@AnthonyLatini you may want to update Esri Case #03479516 - ArcGIS Connectors for Power Automate behaving erratically with that update....
AnthonyLatini
Thank you for the case number @ahargreaves_FW . I will leave a note in there regarding this issue.
ahargreaves_FW
@AnthonyLatini  is this issue in anyway related to the above?
https://community.esri.com/t5/arcgis-for-power-automate-blog/update-11-16-2023-bug-000162586-errors-...
Is a fix on the Power Automate teams radar?
