Date field - from & to
480
6
06-21-2021 04:45 AM
NovicaJ
New Contributor III
I have a date field which I'd like it to be a date field with two values - from & to. I need it to be like a range.
Have two values, a starting date and and end date.
Can this be done somehow?
Marten
New Contributor III
yes, this is possible. you would want to stick to the way this is done in ISO 19115/19139 metadata for time period type extents though. See for example this snippet:
<gmd:temporalElement>
  <gmd:EX_TemporalExtent>
    <gmd:extent>
      <gml:TimePeriod gml:id="1624374152364r23014781936280926">
        <gml:beginPosition>2021-06-01</gml:beginPosition>
        <gml:endPosition>2021-06-22</gml:endPosition>
      </gml:TimePeriod>
    </gmd:extent>
  </gmd:EX_TemporalExtent>
</gmd:temporalElement>
you can find this in the INSPIRE dataset editor in Identification > Resource > Extent > Temporal Extent.
the code for this can be found in: inspire/gmd/extent/TemporalElement.js and the associated template.
Marten
New Contributor III
    <gmd:extent>
      </gml:TimePeriod>
    </gmd:extent>
NovicaJ
New Contributor III
Marten,
Any other changes I need to make in order to save the metadata, regarding the temporal element? Once I click save, I get error 500 in console.
I think I also had to make changes, in other words add the new temporal element field in the Evaluator classes?
Marten
New Contributor III
without seeing the editor, the XML, and/or the error, that is hard to say. Can you share screenshots/files of these 3 things? Does the editor allow you to view the XML? if so, can you add an example here of that?
NovicaJ
New Contributor III
Here is a link for the geoportal and here is the error I get
NovicaJ
New Contributor III
as well as this
NovicaJ
New Contributor III
Marten, I figured it out. Thank you for your help!
