ArcGIS for Excel Function Builder - Access functions from ArcGIS toolbar
1777
12-08-2022 01:04 PM
MrinmayeeBharadwaj
This article was last updated on 12/08/2023
ArcGIS for Excel has formulas similar to Microsoft Excel that you can use to geocode, geoenrich, and route operations. Each function starts with the equal sign in a cell followed by the function name and the cell range it applies to. Once you get acclimated to all these functions, you can easily access them from the Function Builder tool on the ArcGIS for Excel toolbar.
Note: You can use examples from the ArcGIS for Excel functions and formulas help topic to test these functions from the Function Builder.
  1. Open an Excel sheet.
  2. Access the ArcGIS tab.
  3. Click the Function Builder button.
The Function Builder opens in the Task pane, with Choose function and Set parameters tabs visible.
4. Click the Don’t show this again checkbox to skip this welcome screen the next time you want to access the Function Builder.
5. Click OK.
6. The Choose function tab is enabled by default with function drop-down lists visible.
7. If you have chosen a populated cell, or an empty cell, that cell number will be visible in the Choose function pane description, for example G9 in the screenshot below:
8. Choose a function you wish to run from the following options:
Note: Once you choose a function, the related Set parameters tab opens immediately. After populating all parameter fields, you may choose to Add Header, or proceed with running the function by clicking Update.
Tip: To exit a function, click the Choose function tab. This returns you to the functions drop-down lists.
Geocoding functions:
Parameters:
GETADDRESS
Longitude(X) – required
Latitude(Y) – required
Spatial_reference
All_data – type this value as “TRUE”
geocode_service
GETCOORDINATES
Address – required
Spatial_reference
Match_details
geocode_service
Geoenrichment functions:
Parameters:
ENRICHBYPOINT
Spatial_reference
Distance
Unit
Travel_mode
Data_collections
Variables -
- browse through the list of data collections variables. Click Close to exit and return to the ENRICHBYPOINT function pane.
Include_derivative_variables
Include_point_details
ENRICHBYGEOGRAPHY
Area_id
– required. Browse through the list of areas. Click
to return to the ENRICHBYGEOGRAPHY function pane.
Geography_level_id
– required. Browse through the list of countries, and their respective geography levels. Click
Data_collections
Variables -
Include_geography_details
 ENRICHBYADDRESS
 address - Required
distance - Optional
unit - Optional
travel_mode - Optional
variables - Optional
include_derivative_variables - Optional
include_point_details - Optional
Routing functions:
Parameters:
FINDROUTE
From_longitude(X) – required
From_latitude(Y) – required
To_longitude(X) – required
To_latitude(Y) – required
Spatial_reference
Travel_mode
- browse through the list of travel modes supported for routing operations. Click
to return to the FINDROUTE function pane.
Unit
Include_directions
FINDROUTEBYADDRESS
From_address – required
To_address – required
Travel_mode
Unit
Include_directions
Helper functions:
Parameters:
SUGGESTADDRESS
Text – required
Max_suggestions
Country
geocode_service
LISTGEOGRAPHIES
Country
Geography_level_id
to return to the LISTGEOGRAPHIES function pane.
Search_term
exact_match
LISTDATACOLLECTIONS
Country – required
Data_collection_id
Search_term
LISTTRAVELMODES
This function has no parameters. It is already done and displaying results in your chosen cell.
ADDHEADERS
ARCGIS_function - required
Once your Excel sheet is populated with all desired information, do one of the following to return to the map frame:
9. Click x
10. Click the ArcGIS for Excel icon
11. Click Show map
2 Comments
