Tracker in FieldMap
99
Wednesday
AvivLami
I created a map in FieldMap with a line layer that I want users to update by navigating along the way and not by clicking on points along the way and that's how the route will be created, but I can't find the MY TRACKER option in the app (Attached is an example of the screen I am not getting).
And is there a way in the experience builder that I created for the user that he can see the users' navigation along the way live if there is no tracker option?
Thanks.
Eugene_Adkins
Is this something you have used previously?
If not, the answer will depend upon whether you’re using online or portal for your work. Portal requires a data store to be setup. This is not the case for online. Here’s a page that gives a good overview of each. Portal and online vary in the length of time the locations tracks are kept but each should allow the user to view the tracks being created in a viewable layer in the map being used. Here’s a video that discusses some of those viewing options. Here’s a thread from the community that may help with part of your question along with some other questions that may arise from initiating the tracking capability.
Hope this helps.
Eugene_Adkins
Hope this helps.
AvivLami
Thanks @Eugene_Adkins , it did helps a lot.
