"The form contains unsupported data" error when tried to add inspection data to one of related table in mobile Field Map
840
11-26-2023 05:09 PM
RinchenWangdi
Hi ESRI community,
It will be really appreciated if someone has solutions to this issue or has similar problems not resolved.
Issue: The form contains unsupported data error message!
I have 4 related tables to 1 polygon feature layer. Tables have distinct fields but properties are same. When added inspection data via mobile Field Map app, all tables work but except 1 table that gives above error message. Sometimes error shifts to one of the other tables, which has worked before. It is very weird!
Question 1: Can Field Maps (Mobile) hoist more than 3 related tables?
Question 2: Is there a possibility of bug?
Question 3: What is best solution, @esri?
Hoping for the solution soon 🙂
Regards,
Rinchen
RinchenWangdi
Thanks for reply Magisian.
The form does not contain anything that you have mentioned. Please see the screenshots that has fields in the form.
Regards,
Rinchen
ChristopherCounsell
MVP Regular Contributor
It generally means there is unsupported data in your form, or a field is in the form that shouldn't be.
e.g. sometimes there's issues when raw html is being inserted, or a form expression is invalid to the data type.
Other times it's because a field like Shape is in the form and shouldn't be. Check your form field for reserved words like Shape_length, Shape_area, or common database words like DELETE etc.
Otherwise to assist further we'll need to see screenshots of the form, the fields in them, and ideally the ArcGIS Field Maps logs. Technical support will be able to actively and privately review these as well if you have concerns posting them on the Esri Community.
RinchenWangdi
Regards,
Rinchen
