Some issues with form calculations in Fieldmaps when offline.
The value wanted should be the username of the person using the app. All works fine when connected (getUser() from portal in a connected environment works as expected), but is there something we're missing (maybe in the way how the app is configured for offline) which would allow this to work when not connected?
Yes its been posted a few times. Check out this post
and maybe https://community.esri.com/t5/arcgis-field-maps-questions/form-calculate-getuser-offline/m-p/1166748
