Autofill fields in subsequent record based on previous record?
105
4 weeks ago
JosephZebrowski
My field crews need to be able autofill a field in subsequent record based what was entered for that field in the previous record? A version of this question was answered in the negative. "Autofill some fields in subsequent record based on first record?"
Recent values won't work because I do not have a domain to draw from. It is not practical to create one.
This appears to be a common capability with other non-ESRI field data collection apps. I have been searching for an answer to this with no luck other than the response referenced above.
I imagine there is an Arcade script that I am just not finding.
Any help will be greatly appreciated.
AndreasHall
Hi, I do not now the solution to your problem but found this post about a similar issue. Does it help you?
Solved: Populate a field in the current record from the pr... - Esri Community
