Hello!
I have a small Arcade expression I'd like to use in a field map. It takes a feature set from the map, which is filtered from a broader feature service, and generates a "custom" id for any newly added feature.
Solved! Go to Solution.
If you wrap the feature set with a Filter and the map's definition query you can guarantee the feature count matches the map in every context.
Hey @BrianPryzby
Would there be any reason where you wouldn't be able to use GUID()?
var POI = $feature.POI_ID
if (POI != null) {
return POI
} else {
return "POI-" + GUID()
This would avoid the FeatureSetByName issue entirely, also generating a unique ID.
https://developers.arcgis.com/arcade/function-reference/text_functions/
Cody
Hi Cody, thanks for your response! This definitely would work as a way to generate a unique identifier, though I was looking for something a bit simpler. Just a sequential ID, POI 1, POI 2, etc. that would be unique to each map. There can be repeats within the broader feature layer
Thanks David, this worked for me! It seems a bit redundant that you'd need to place a filter on a feature set, which was itself rooted in a filtered layer on a web map. But it is what it is
