Expressions Fields Display Order - Can't be Reorder to the Top of the Pop Up
981
05-13-2022 04:15 PM
Status: In Product Plan
Labels (2)
rsun_TQB
Occasional Contributor III
I made expression to generate links to Survey123 survey with latitude, and longitude. However, my expression fields are not displayed in the same order that I had on Pro and New Web Maps...they are put at the cold bottom after all other attributes.
Web Map/Pro can display with my configured order
Field Maps
I need to scroll to the bottom to find my expression made links.
Using ArcGIS Enterprise 10.9.1
Reno
2 Comments
by Anonymous User
The issue is that Field Maps doesn't support the newer pop-up formats that Map Viewer and Pro author. This is something we just started work on and plan to deliver later this year. If you use Map Viewer classic to configure the pop-up, the order should be respected.
rsun_TQB
Hi @Anonymous User !
Thanks! It resolves the issue! Hope Field Maps will support new Map Viewer and Pro soon.
Thanks a lot!
Reno
