Using a map image layer (ie not feature layer) with the Chart Widget
148
a month ago
MetteTranter
Hi, I am using Enterprise v 11.1. I want to use the Chart Widget to create a bar or pie chart using date loaded in as a map image layer rather than a feature layer. When I try to assign the fields for the chart (either by group or by field) I get an error. A little error triangle appears on the chart and says "failed to load". It works if I use a feature layer.
Should the chart widget be able to work with a map image layer?
thanks
Mette
WeiYing1
Hi @MetteTranter ,
Thanks for your feedback! Experience Builder Chart widget does support map image layer.
I cannot reproduce the problem using map image layer on my side.
Would you be able to share the data or repro app for us to take a further investigation?
Wei
