I have a use-case in which I would like to use a data view in a data_filter url parameter.
In the filter, I want to populate the count of a data view that is created from a layer.
The url parameter would be placed inside of the web map popup, and lead the user directly to the filtered page for that data view text.
I am able to successfully filter an operational layer in the application when I refer to the <webmap_id>-<layerid>, in this case:
dataSource_1-18a09b4c123-layer-1
I am NOT able to filter the data view created from that layer:
I obtained the data view's id from the app's item_data in the form of a json text (using arcgis assistant).
In this case, the view's id is:
dataSource_1-18a09b4c123-layer-1-dataView_1:
The json shows this configuration for how the text is derived in the app:
"text": "<p>Arrivals: <exp data-uniqueid=\"30b6aeb7_1db3_adce_2edf_80afb82fe54f\" data-dsid=\"dataSource_1-18a09b4c123-layer-1-dataView_1\" data-expression=\"%7B%22name%22%3A%22%20%22%2C%22parts%22%3A%5B%7B%22type%22%3A%22FUNCTION%22%2C%22exp%22%3A%22COUNT%22%2C%22dataSourceId%22%3A%22dataSource_1-18a09b4c123-layer-1-dataView_1%22%7D%2C%7B%22type%22%3A%22OPERATOR%22%2C%22exp%22%3A%22(%22%7D%2C%7B%22type%22%3A%22OPERATOR%22%2C%22exp%22%3A%22)%22%7D%5D%7D\"><span contenteditable=\"false\"> </span></exp> </p>",
Out of that piece of json, I'd think the 'data-expression' string would be relevant to grab for the url parameter to control the dynamic text.
Here is that string for better visibility:
"name": " ",
"parts": [
"type": "FUNCTION",
"exp": "COUNT",
"dataSourceId": "dataSource_1-184ce793cfa-layer-9-dataView_1"
"type": "OPERATOR",
"exp": "("
"type": "OPERATOR",
"exp": ")"
I am using ArcGIS Enterprise 11.2
At this time, this is the only related post:
I would appreciate anyone's help:
