Trying to remove popup 'Collapse' button in mobile layout
99
Tuesday
FranklinAlexander
Occasional Contributor III
Does anyone know how to remove the Collapse button in the popup header? The button doesn't do anything useful when in mobile layout and takes up valuable space.
popup_collapsed.PNGpopup_noCollapse.PNG I would like to remove the button altogether, but can't find a css solution. I have tried setting the display to none using the custom theme styling.ts file, but cannot find the right class/attribute/tag combination to get it to work. I was able to remove the Dock/Undock button using the following :
calcite-action button[aria-label="Undock"] {
      display: none !important;
Nothing has worked for the Collapse button, however, so I am wandering if it is even possible using the stylesheet. There may only be a coding solution to this, but I don't know where in the code the popup headers are being created. I know it's a longshot, but if anyone has a solution or suggestion that would be great. I am using EB Developer v1.14.
