Hi all,
I am thinking of making a web app where a user can digitize a polygon and have a widget or tool that is able select all the points than fall within the digitized polygon and export it as a excel spreadsheet.
Does anyone know if there is a widget or tool out there within experience builder that will do this that does not require custom coding?
Thanks for any pointers,
L
You could try adding a query widget to you app and allowing a spatial filter based o geometries from the map. As long as you have data actions on for the query widget you can export the results to csv.
