I am configuring the Query Widget on Experience Builder; there are 4 queries that I have, each has their own color icon. I am trying to have that color icon to appear on the map once that particular query is selected, but it looks like that's not an option like it was in Web AppBuilder? the only thing I see is having a custom color appear on the map for the Query widget as a whole.
Does anybody have a solution to this?
Thanks!
You could try using multiple Query Widgets.
To make it work well in your layout, you can use a Grid Widget then add each of your Query Widgets to the center. This should make a tabbed layout with your different queries.
I am trying this now and its working well, thank you!😄
