Print widget does not create PDFs
184
5
3 weeks ago
SanchezNuñez
Good afternoon,
For some web maps the print widget does not export ethe map to a PDF format.
How can I find a solution to this.
MichaelVolz
Esteemed Contributor
Are you using the default ESRI print service or a custom print service?
JoseSanchez
Good morning @MichaelVolz
How can I check if I am using the default ESRI print service?
JoseSanchez
We are using the default ESRI print service.
Debert
ArcGIS Pro > Share tab > Export Map > you have both Flattened and Vector PDFs to choose from.
You could also create a layout and print from there as well.
I am the GIS Admin for Iowa Regional Utilities Association.
Find me on Linkedin.
JoseSanchez
Good morning @Debert
This print button is for end users who are printing form a web viewer. Most of them do not have ArcGIS Pro installed locally.
