Greetings everyone,
I started working on ArcGIS Experience Builder for about 3 weeks.
I have followed the examples and tried to learn however, there is a lot of things that are blur to me.
1. I would like to know where can I find the file location of the experience ( which will includes all out-of-box widgets + my custom widgets ) and will I be able to implement my logic at that level, and how ?
2. I have a custom widget that has a button in it, I want onClick to perform some function then route to the other page. ( assuming we have page 1 and page 2 ).
How can that be achievable ?
Thanks and best regards
If you're using the developer edition, everything should be in /server/public/apps/your-app-id in the ExperienceBuilder folder. I don't have experience implementing custom widgets, however.
Thank you Josh for the reply,
However, I have seen the content of the /server/public/apps before and all it have is a configure json files.
What I am interested in, is how to implement a function at "pages" level to ensure authentication, no unauthorized access can get to the application.
If you are looking for the out of the box widgets, you can find the source code for them under the client/dist/widgets folder.
If you wanted to modify the code you would have to copy the code out and push it the your-extensions folder and then add your code in as a custom extension of the original widget.
If you want to programmatically change a page you can simply do that implementing the below,
window.location.href = "/?page=page_1";
Though this will cause a page refresh, the alternative would be to look at the available dispatch options as I believe there should be an option in there to change the page, though I have not needed to use it, only change sections.
Cheers
Grant
Thank you Grant for your efforts,
I have tried looking into the source code and check how the widgets been implemented, however I did not achieve my goal.
I would give you an example, maybe there is a work around that can be done.
I have the following code:
const onSubmit = () => {console.log('authentication...')}
<Link id='redirectTO' to={linkTo} target={target} onClick={onSubmit }>Login</Link>
I want to make sure that the Link component does not go to the next page unless the onClick function executes successfully.
