Is there an option to change bar chart colours?
181
10-21-2021 06:34 PM
Hayley
Instead of having three blue bars, is there an option where I can change each bar to different colours?
jcarlson
MVP Frequent Contributor
Click on Series, then click the Edit icon next to the series name. You'll see a Symbol section which will enable you to change the bar color.
However, this will only work for the entire series. It appears your chart is configured to show the values per field, and that will consider the fields as separate items in the same series.
Without reshaping your data, I don't know that you can get individual items in a single series to be colored differently.
- Josh Carlson
Kendall County GIS
Hayley
Hi Josh, thanks for your response.
So in order to get different colours, I would need each field to come from a different data source?
